Forum rules
 Post subject: Name this SSD interface
PostPosted: August 23rd, 2012, 2:42
Does this SSD interface have a special name? And if its non standard how to interface with it outside the laptop?
Zero Alpha: zeroalpha.com.au
 Post subject: Re: Name this SSD interface
PostPosted: August 23rd, 2012, 4:11
This is mSATA connector.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: August 23rd, 2012, 8:57
yes mSATA ... inside a ASUS Zenbook :)
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: August 23rd, 2012, 19:51
Thank you very much kind gentlemen
PostPosted: September 11th, 2012, 0:12
I purchased a mSATA adapter and it does not fit this SSD at all. Does anybody know a more specific name for this SSD card?
PostPosted: September 11th, 2012, 2:19
Can you take picture from other side of SSD and empty slot.
On mSATA should be marker pin in the middle of connector not on edge like on SATA.
Like last idea check is the connector looks like mPCI .
PostPosted: September 11th, 2012, 14:27
Can you write model of motherboard? (Wistron/Quanta/Inventec? and model).
PostPosted: September 11th, 2012, 14:45
Some comments on this SSD and also the one from some Macbook Airs
http://www.anandtech.com/show/5854/asus ... compatible
Most importantly,
In other words, the MacBook Air and Zenbook SSDs are not compatible with one another.
One last thing, neither of these SSD form factors is compatible with mSATA although they look similar at a distance. mSATA features a wider, double-sided connector with more pins than either of these two options.
PostPosted: September 11th, 2012, 22:06
Thanks for posting the article drc and the replies from other members. Manufacturers should stick to industry standards!!! The customer has put this in the too hard basket so I am closing this thread.
