Forum rules
 Post subject: Seagate 7200.12 “Init SMART Fail” investigations
PostPosted: January 15th, 2014, 14:57
What’s the latest findings on this ?
Lots of threads on here about this type of 7200.12 busy issue
that shows up as
Init SMART Fail
LED:000000CC FAddr:xxxxxxxx
normally appears after trying to clear SMART with F3 1>N1
eg
viewtopic.php?f=1&t=16552
viewtopic.php?f=1&t=17823
viewtopic.php?f=1&t=23999
viewtopic.php?t=24883
etc
Latest F3 drives 7200.12 and 5400.6 etc
I have a 1TB ST31000528AS 7200.12 drive doing this
Don’t need to recover data, just want to get the drive working again and/or use it to investigate this issue
Hence could risk some m0, commands … [Don’t do this unless experimenting]
V40 was empty, so should be safe
V4 had lots of reallocated entries
Tried lots of m0, commands, some error-ing out at a few %, some reaching 100% after several hours
(as per viewtopic.php?f=13&t=27618)
some leading to InitiateMarkPendingReallocateRequest errors
Eventually got to a 100% state which seemed to largely fix it
Now have new V40 entries
V4 empty at present
Drive would go ready and all sectors readable (a few bad/slow sectors)
but ata interface cant read smart – gets UNC? error
Terminal F3 1>N5 can read the raw smart data
but N1 to clear smart pauses then gives the
Init SMART Fail
error still
Still investigating what is causing this and if any way to fix it fully
V4/V80 has gained some reassigned/glist entries
probably as a result of the ATA level surface scan
Drive is 1TB ST31000528AS CC37
could maybe do firmware update to CC49
http://knowledge.seagate.com/articles/e ... uage=en_US
 Post subject: Re: Seagate 7200.12 “Init SMART Fail” investigations
PostPosted: January 20th, 2014, 10:11
Banned User
At F3>T m0,2,2,,,,,22
if user partition format successfully you can clear smart with N1.
PostPosted: February 12th, 2014, 15:33
Just to recap, the 'refurbished' drive is working well
All sectors readable at SATA interface (a few bad/slow sectors)
but sata interface cant read smart – gets UNC? error
Init SMART Fail
error still
Since I know (approx.) where the raw smart data and stuff in the SA is (see my Reading user and SA sectors from terminal tutorial thread) I might start looking round there
Strange that N5 read reads ok
but N1 clear has an issue (relating to one of the SA areas it accesses?)
Users browsing this forum: No registered users and 96 guests
