Forum rules
 Post subject: Firmware for Seagate Barracuda 7200.9 80gb ST3808110AS 3.ADH
PostPosted: November 6th, 2014, 20:00
Hello to everyone,
I have a problem with the HDD Seagate Barracuda 7200.9 ST3808110AS 80 GB FW 3.AAE, I would change firmware of this HDD to version 3.ADH for replace it on a same hard drive.
Anyone has the firmware file?
Anyone know if this hard disk will work the same without change firmware?
Many thanks. Regards
 Post subject: Re: Firmware for Seagate Barracuda 7200.9 80gb ST3808110AS 3
PostPosted: November 7th, 2014, 3:37
viewtopic.php?f=16&t=12671
 Post subject: Seagate Barracuda 7200.9 ST3808110AS: сhange firmware versio
PostPosted: November 8th, 2014, 18:51
I believe I may not correctly understand what you're looking to do:
you need a drive with the FW version 3.ADH (probably to use with some hardware, which won't accept any other), but you only have drive with FW ver 3.AAE and you want to make it report different FW version (3.ADH)?
