Forum rules
 Post subject: RAID 50 XOR Set Separator
PostPosted: October 13th, 2015, 12:14
I've started work on a project to brute force XOR Hex values pulled from members of RAID 50 sets and separate them into their respective RAID 5 sets. The need for this came up when I had to handle a 16 drive array with no idea which drives belonged in which set.
I've posted a sample of what I'm putting together here on my forum: https://www.data-medics.com/forum/raid- ... t1036.html
I'd post it here too, but I lack the necessary admin privileges to embed an Excel sheet into a post. Looking for any input, suggestions, or anyone who'd like to be involved with this project. Getting into bigger arrays, this might get to be a mess.
 Post subject: Re: RAID 50 XOR Set Separator
PostPosted: October 16th, 2015, 15:36
You can probably use entropy analyzer from our ReclaiMe Pro to solve half of the problem. You can use it to convert 16 disks into 8 pairs, from which point manual analysis should be fairly easy.
PostPosted: October 23rd, 2015, 13:50
Hi ,
I did send a Eval Request To Reclaime but never used the tool .Will do again jared has a good experience in his forum also for your tool
PostPosted: October 24th, 2015, 9:45
Sometimes better and faster to use service fw data located at the beginning or end of each hdd, where you can find order of ther drives:
Sample for Areca controllers:
AnexTEK storage iSCSI 16 drives , based on Areca , with meta.JPG [ 219.39 KiB | Viewed 11620 times ]
Angel Data Recovery
PostPosted: December 20th, 2015, 7:23
Unfortunately not all controllers write that information to the drives...
