Forum rules
 Post subject: Put Dell firmware to non Dell hdd
PostPosted: April 7th, 2018, 2:07
I have 15 seagate constelation es ST1000NM0001 drives. Dell server with 5/i gives me - wrong type, 6/i - can not initialize. My guess the reason is non Dell firmware.
I have seen several old threads about it without any clear result. Is it possible to put dell firmware? Or e.g. if I would buy 1 Dell ST1000NM0001 can it be cloned among them.
Thank you in advance. any help is uppreciated
 Post subject: Re: Put Dell firmware to non Dell hdd
PostPosted: April 7th, 2018, 17:31
I tested a couple of SATA disk and they work fine :( I am not able to realize what's wrong with ST1000NM0001
PostPosted: April 7th, 2018, 18:03
It could be that Dell expects a different sector size:
http://forum.hddguru.com/viewtopic.php?t=36516&p=256616#p256616
https://www.seagate.com/www-content/product-content/constellation-fam/constellation-es/constellation-es-1/en-us/docs/100650925g.pdf
User-selectable logical block size (512, 520 or 528 bytes per logical block)
PostPosted: April 7th, 2018, 18:14
thank you for your reply! You gave me hope. I see it must be non Raid card. So Dell 5/i and 6/i I have does not fits as I understand? Just to confirm since I do not have any other and it seems I have to buy.
PostPosted: April 7th, 2018, 19:56
I have no relevant experience. I'm just the messenger.
PostPosted: April 8th, 2018, 20:10
Thank you so so much! You made me happy! really!! it works!!! thank you again
Users browsing this forum: No registered users and 102 guests
