Forum rules
 Post subject: IBM SSD SECTOR SIZE PROBLEM
PostPosted: March 2nd, 2024, 11:48
I have a few IBM SSDs. The sector size of these SSDs is 528 and I cannot change it to 512. I am getting error as below. Is there anyone who provides free or paid support service on this issue?
root@diskformat:~# smartctl --all /dev/sg1
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-97-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor: IBM-SSG
Product: IBM-SSGSSJ315P
Revision: E2DA
Compliance: SPC-5
User Capacity: 15,284,010,221,568 bytes [15.2 TB]
Logical block size: 528 bytes
Physical block size: 4224 bytes
LU is resource provisioned, LBPRZ=1
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Logical Unit id: 0x5000c500bb30277c
Serial number: ZFX010HH0000822150Z3
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Sat Mar 2 15:48:08 2024 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Temperature Warning: Enabled
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Percentage used endurance indicator: 0%
Current Drive Temperature: 36 C
Drive Trip Temperature: 65 C
Accumulated power on time, hours:minutes 681:46
Elements in grown defect list: 0
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 0 1661 1661 1661 15697.669 0
write: 0 0 0 0 0 11736.471 0
verify: 0 0 0 0 0 9072.263 0
Non-medium error count: 0
No Self-tests have been logged
root@diskformat:~# sg_format -v --format --size=512 /dev/sg1
IBM-SSG IBM-SSGSSJ315P E2DA peripheral_type: disk [0x0]
PROTECT=0
Unit serial number: ZFX010HH0000822150Z3
LU name: 5000c500bb30277c
mode sense(10) cdb: [5a 00 01 00 00 00 00 00 fc 00]
Mode Sense (block descriptor) data, prior to changes:
block count maxed out, set <<longlba>>
mode sense(10) cdb: [5a 10 01 00 00 00 00 00 fc 00]
<<< longlba flag set (64 bit lba) >>>
Number of blocks=28946989056 [0x6bd600000]
Block size=528 [0x210]
mode select(10) cdb: [55 11 00 00 00 00 00 00 24 00]
mode select(10):
Descriptor format, current; Sense key: Illegal Request
Additional sense: Invalid field in parameter list
Descriptor type: Sense key specific: Field pointer:
Error in Data parameters: byte 21 bit 7
Descriptor type: Field replaceable unit code: 0x11
Descriptor type: Vendor specific [0x80]
00 00 05 26 00 11 ff ff ff ff ff ff 00 00
Try MODE SELECT again with SP=0 this time
mode select(10) cdb: [55 10 00 00 00 00 00 00 24 00]
mode select(10):
MODE SELECT command: Illegal request, type: sense key, apart from Invalid opcode
root@diskformat:~#
 Post subject: Re: IBM SSD SECTOR SIZE PROBLEM
PostPosted: March 18th, 2024, 15:15
Try
sg_format -v --format --size=4096 /dev/sg1
, as most SSDs don't have/support 512 anymore.
If this doesn't work it's maybe opal/native encryption lock or sth. you need to unlock first before you can reformat to anything. If this also won't work, you need generic firmware but I doubt that it's possible with this disk.
