Forum rules
 Post subject: Seagate HD shutdown when we read the 18.000.000 sector
PostPosted: August 26th, 2008, 4:30
Hello HDGurus.
We need to recover data form a Seagate HD.
Our problem is that when we arrive to the 18.000.000 sector (approximately) reading the hd with a recovery software, the HD shutdown and we can not progress with the data read.
any idea?
Thaks for your help.
 Post subject: Re: Seagate HD shutdown when we read the 18.000.000 sector
PostPosted: August 26th, 2008, 5:03
Use some non-windows imaging s/w.
Preferably something with reverse cloning support. (e.g. MediaTools Pro or dd_rescue).
Image to a good drive, then recover from that.
Sean
PostPosted: August 26th, 2008, 5:19
Thanks I try it now.
PostPosted: August 28th, 2008, 5:43
Hi to all gurus.
I am trying with MediaTools Pro. I am trying to copy disk to disk with reverse and with out reverse option, but this is the result:
With out reverse clone: at 4% of clore (aprox 18.000.000 sectors, the same before) the hd shut down
With reverse clone: at 1% of clore the hd shut down.
Any idea?
Thanks.
PostPosted: August 28th, 2008, 12:35
You'll probably need some pro cloning tool that'll control the power to the HDD when required.
e.g. Data Extractor or DeepSpar
If you're in UK, or can ship to UK, I can do this for you.
Sean
