Buy/sell hard drives, parts, tools
I need a strange Wester Digital HD
May 27th, 2010, 11:18
I need a exactly donor (Western Digital 2´5 HD) to change the platters. My PCB it´s burned but
not carbonized completely, but the ePROM doesn´t survive. I can read yet a part of the code.
PCB CODE: 2060-701615-003
I don´t know the p/n, firmware or the DCM codes. However, I suspect it may belong an HD of
the Scorpio Blue or Scorpio Black series like:
wD3200BJKT
WD2500BJKT
WD1600BJKT
WD3200BEKT
WD2500BEKT
WD1600BEKT
It has two pairs of heads and two platters and micro-USB connector located at the PCB. It hasn´t SATA neither
IDE connectors.
Please, answer the following questions as soon as posible:
Anybody has a similar HD with micro USB located at the PCB without IDE or SATA connections?
Anybody knows which would micro-USB connector be included at the PCB?
Anybody has seen a notebook with micro-USB connections exclusively to connect the HD´s to the mother board
directly?
Thanks!
Re: I need a strange Wester Digital HD
May 27th, 2010, 16:30
Read the barcode on the drive chassis with a barcode scanner. This will give you the serial number. Input this to the WD warranty site and it will tell you which model it is. Thanks to a well known member for helping me with this recently :)
Based on the damage that you posted earlier, I agree with Dobre, I doubt this drive is recoverable.
May 27th, 2010, 19:08
hi,
it's looks should be WD PP hard drive.Image
would you like to post images of your PCB? may be i can help. i have some donors for it.
May 28th, 2010, 3:08
I think that's the PCB. I add the picture right now.
May 28th, 2010, 8:10
CK wrote:Read the barcode on the drive chassis with a barcode scanner. This will give you the serial number. Input this to the WD warranty site and it will tell you which model it is. Thanks to a well known member for helping me with this recently :)
Only problem with this in this case is that since it is an external, I think the serial number will only get him the model of the external, rather than the model of the drive
June 1st, 2010, 17:08
this seems like the one im working on.
came from wd my passport WD3200ME-01 3110A. except yours is older
my info on it says 2061-701615 AD
DCM: HACT2AB
WD3200BMVU-1104S0 ( yours is older prob different)
