 Post subject: Needed PCB for WD 320GB Caviar HD, MFD 13 DEC 2006
PostPosted: January 11th, 2011, 18:17
Does anyone have a working PCB for this HDD or know where I can get one?
MDL: WD3200JB-0KFA0
DATE: 13 DEC 2006
DCM: HHBHCAJCHN
Need it to recover data of the drive, can return if you cannot part with it permanently.
 Post subject: Re: Needed PCB for WD 320GB Caviar HD, MFD 13 DEC 2006
PostPosted: January 12th, 2011, 6:53
You will need to transfer the flash memory chip at location U12 from patient to donor. A straight board swap won't work.
Try here:
http://www.hdd-parts.com/firmware-transfer.html
The supplier includes a firmware transfer for US$20.
PostPosted: January 12th, 2011, 8:01
Thank you for the info fzabkar,
I was under the impression that if I get a board from the approximate same date with same specs, that has not been flashed, it should work. My board is fine, except for the contacts from the PCB to the drive.
I get connection with the drive and see the data if I plug the drive in about 50-100 times on external USB, this is naturally not ideal when trying to recover data :), but i have recovered about 135GB of the 260GB this way, but now out of luck. The drive boots up for about 30 sec. then freezes up again. I initially tried nondestructive recovery with a few different professional programs, that did not work at all, tried to recover through Linux, did not work, then Win 7 and with a little patience, voila, half recovered, I guess i will stop cursing Mr. Gates :)
I will contact the site you suggested and see if they can assist me with this. If you think of anything else i can do then I would appreciate the input.
PostPosted: January 12th, 2011, 16:57
The problem sounds more like bad media or a bad head than a PCB fault.
If you don't move U12 to your donor board, the drive will probably click and fail to be detected at all.
PostPosted: January 12th, 2011, 18:33
You could be correct, question is, will it hurt to try, I should be able to go back to the old board without any harm them. What do you think?
PostPosted: January 13th, 2011, 11:05
Hi, We have this kinds of PCB in stock, pls contact my hotmail to see if I can help or not.
Thanks, Eric.
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: January 13th, 2011, 17:05
It should be OK, as long as you don't damage the flash chip in the process. Then you will need professional recovery services.
Some suppliers, eg http://www.hdd-parts.com/firmware-transfer.html, will include a firmware transfer service for US$10 - $20.
PostPosted: January 13th, 2011, 17:29
fzabkar,
I think I will try the swap first if I can locate the correct PCB.
I have sent an email to the guys at ttha link, waiting for a reply, thanks again.
PostPosted: January 16th, 2011, 23:00
hi,
i have this PCB in stock. please contact me by email or skype if need help.
data recovery service[/b]
PostPosted: January 17th, 2011, 14:18
networkpc3000, thanks for the info.
I am currently waiting for a board that is being sent to me. If nothing comes of that I will be in touch.
Users browsing this forum: No registered users and 92 guests
