Buy/sell hard drives, parts, tools
Need Maxtor STM3160215AS
February 23rd, 2011, 12:33
Looking to purchase a Maxtor DiamondMax21, STM3160215AS, Country Of Origin: Thailand, Date Code: 09015, Firmware: 4.AAB.
Re: Need Maxtor STM3160215AS
February 24th, 2011, 0:27
hi,
please let me know minimum matching way. i will check for you soon. thanks.
February 24th, 2011, 4:49
Can you describe the failure symptom?
If you upload a detailed photo, one of us may be able to help you repair your board. Many times the problem is only a shorted diode, in which case it can simply be removed.
Otherwise, if you need a board ...
http://www.onepcbsolution.com/stm316021 ... small.html
The price is US$40, plus $10 for a firmware transfer. The 8-pin serial flash memory chip, or its contents, must be transferred to your donor. It is located in the top left corner of the following photo:
http://ep.yimg.com/ca/I/yhst-4446369223 ... 45_2644092
