Buy/sell hard drives, parts, tools
Need a WD WD5000AAKS pcb
May 11th, 2010, 1:25
Folks,
i am looking to buy a WD5000AAKS pcb. Model: MDL: WD5000AAKS-00YGA0, DCM: DHNNHT2AAN and label on pcb: 2061-701477-900 AD
Thanks!
Bearcat
Re: Need a WD WD5000AAKS pcb
May 11th, 2010, 3:26
Unless you have PC3000 or Salvation WD Doctor, then a new PCB will be no good to you.
ROM inside MCU has unique data programmed into it, and needs to be reprogrammed using the original data or remanufactured data from info on the service area on the platters.
Please don't waste your money.
May 11th, 2010, 19:06
hi,
i have this PCB in stock and be able to help you program original FW to good PCB. just simple swap PCB won't help at all. please contact me by email or MSN if still need help. thanks.
May 12th, 2010, 2:24
Can you describe the failure symptom?
If you upload a detailed photo, one of us may be able to help you repair your board. Many times the problem is only a shorted diode, in which case it can simply be removed.
Otherwise, if the drive spins, but is not detected, then it is most likely not a PCB problem.
Good luck.
May 12th, 2010, 8:41
Hi
We have this working PCB in stock too, but you have to reprogram rom in main chip.
Eric
April 27th, 2012, 11:54
I have a wd5000aaks with the same problem.
On the pcb, I don't have a 5v on the 13th leg in the connector, as shown in the photo.
Thanks for any help!
April 28th, 2012, 17:40
The following PCB supplier includes a free "PCB adaptation" service:
http://www.donordrives.com/blog/pcbswapguide
"If you cannot find a ROM chip [ie if location U12 is vacant], and are working with a Western Digital hard drive, then it is likely imbedded in a main controller Marvell chip. That chip is extremely difficult to solder, and most of the time experts do not have success with it. Our company offers Free PCB Adoptation Service to customer who have made a purchase from our store. The new PCB will be reprogrammed to work with hard drive, with no soldering including in the process, whatsoever."
May 2nd, 2012, 0:50
I have this pcb. Check your PM
