Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: [WANTED] ===Seagate Barracuda 7200.9 ST3300622A 300GB IDE===
PostPosted: October 4th, 2008, 20:25
I have already recovered the data. I just wanted to figure out what component was that. I'm not going to buy the new hard drive as now everything works fine but I can use only one HD at at time. If i need another HD I have to solder the part back.
I found that component. It is a transient voltage suppressor from ON semiconductors 1SMA5.0AT3 device code is QE which means that the working voltage is 5.0 volts. Hence, i've almost solved my problem :)
PostPosted: October 4th, 2008, 21:23
Glad you worked it out. This part has been discussed so much, I assumed you knew what it was. Search TVS to see what I mean :)
PostPosted: November 28th, 2012, 11:32
are you still in search of an ST3300622A 300GB HDD because I have one available but mine is 3.AAH Firmware and the site code is WU. IT works perfectly fine so let me know.
Users browsing this forum: No registered users and 92 guests
