 Post subject: Wanted - Western Digital 1TB Donor Drive
PostPosted: August 8th, 2015, 20:16
to try and recover my data quicker I'm helping my DR company look for:
WD 1.0TB USB3.0 Drive
MDL: WD10JMVW-xxS5Xxx
DCM: EHCTJBNB
DATE: 21 OCT 2012
Regards,
MF
 Post subject: Re: Wanted - Western Digital 1TB Donor Drive
PostPosted: August 8th, 2015, 23:42
some details are missing like country of manufacture, head map, preamp rev.
PostPosted: August 9th, 2015, 0:12
Ok I'll ask the data recovery service for that information
PostPosted: August 9th, 2015, 0:28
PostPosted: August 12th, 2015, 2:57
jermy,
I've spoken to the data recovery service and they don't want to power it up as this may cause irreparable damage. They did so however that as it is a 1TB capacity it uses all heads.
Not withstanding the above, can you help with a donor drive ?
MF
PostPosted: August 12th, 2015, 5:42
i would suggest to let company search the donor, i think this is what they want. these passport drives are friendly for HSA compatibility so should not be a big deal.
RAID/Server Recovery
PostPosted: August 12th, 2015, 6:30
no need to power the drive for that, it can be done by reading the ROM with PCB only (Boot ROM mode), or using an external programmer
what about preamp rev ?
ask them a copy of ROM (as explained above (PCB only or using an external programmer)) upload here, and i'll try my best.
PostPosted: August 12th, 2015, 6:51
edit: what about the country of manufacture
