 Post subject: mac air ssd card reader
PostPosted: October 28th, 2016, 0:23
hi,
anyone who are interested in this. please contact us at sos@thailanddatarecovery.com. we sell it at $15. for the details, please see below.
ONLY works on 17+7 pins 2012 New MacBook Air SSD which mainly uses on
MacBook Air's SSD - A1466 13-inch (MD231, MD232), A1465 11-inch (MD223, MD224)
It Also can use in 2012 MacBook Pro Retina's SSD.
2012 MacBook Pro Retina's SSD and 2012 MacBook Air same Pins definition, Only Different Size (Shorten)
Use another Screw Hole is OK if using 2012 MacBook Pro Retina's SSD.
NOT suitable for 12+6 pins 2010/2011 MacBook Air SSD which mainly uses on
MacBook Air's SSD - A1370 11-inch ( MC505 MC506 MC968 MC969), A1369 13-inch (MC503 MC504 MC965 MC966)
It's have Power Regulator from 5.0V to 3.3V.
When you upgrade your MacBook Air's SSD and don't know how to deal with the old one?
Here is the solution for you.
This card is made to convert MacBook Air's SSD interface to standard SATA interface.
Compatible with standard SATA 2.0 hard disk.
Easy install and great quality.
Physical size:128mm x 43mm x 12mm (height) ( Un-Fit on notebook)
3.3V circuit.
best regards,
