 Post subject: Read leatest monoliths UFD from Samsung without soldering !
PostPosted: August 14th, 2020, 8:38
Hello guys,
We are working hard every day to make your work DR work faster and easier - we are not sleeping in holiday season ;) Today we are back with pack of new products ;) Finally we can announce that NEW monolith MR UFD adapters are READY !
* Links to products, movies you will find at bottom ;)
- Monolithic UFD flash drive MR UP06 NAND adapter for Samsung FIT DUO BAR
- Monolithic UFD flash drive MR UP05 NAND adapter for Samsung FIT DUO BAR
- Fully configurable MR TSOP48 Wide adapter
Let's start with MR UP06
Support Samsung flash drive FIT, DUO, BAR - model 2020 version 32GB
Samsung flash drive where you can find this monolithic NAND memory:
MR UP05
Photos of the adapter:
Support Samsung flash drive FIT, DUO, BAR - model 2020 version 64GB, 128GB, 256GB
For those of you who need 2 pcs set it's ALSO ready ;)
MR TSOp48 WIDE
Photo of adapter:
Photo of adapter with mounted socket for 8 bit readout:
Pictures of the adapter with individual configuration of connections for TSOp pins (configurable via DIP Switch to ground or power supply):
Link to shop with MR UP06 - https://multi-com.eu/shrt-ESIiqK2qc
Link to shop with MR UP06 - https://multi-com.eu/shrt-lbLe5x4XP
Link to shop with MR UP06/UP05 set - https://multi-com.eu/shrt-CUtajzEDW
Link to shop with MR TSOP48 WIDE - https://multi-com.eu/shrt-4yiZgkxS
Link to YouTube video from connection of UP06 - https://www.youtube.com/watch?v=P2fPEAse_mg
Link to YouTube video from connection of UP05 - https://www.youtube.com/watch?v=N74pxuCVltQ
P.S#1
Full range of ALL available models, supported cards, movies you can see at https://multi-recovery.com
More about our previous projects you can read at:
- eMMC/eMCP NAND adapters - https://forum.hddguru.com/viewtopic.php?f=15&t=37381
- microSD NAND adapters - https://forum.hddguru.com/viewtopic.php?f=15&t=35872
- microSD NAND VIAS adapters - https://forum.hddguru.com/viewtopic.php?f=15&t=38543
- SD NAND adapters - https://forum.hddguru.com/viewtopic.php?f=15&t=38862
P.S#2
Companies interested in reselling contact directly to biuro@multi-com.pl for quotes.
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
 Post subject: Re: Read leatest monoliths UFD from Samsung without solderin
PostPosted: August 14th, 2020, 14:22
Fixed link to video from connection of UP05 - https://www.youtube.com/watch?v=0zRxdHqhsxE
Best regards,
Boguslaw Rzepka,
PostPosted: August 14th, 2020, 21:22
for us poor people it is like sitting on the porch watching Lamborghinis drive by ;-)
But in any case the time and work you put in to these, I envy the people that get to use them!
nice work.
