 Post subject: New adapter ATAG and TSOP56 is ready !!!!
PostPosted: November 7th, 2024, 10:20
New adapters are ready !!!!
ATAG NOR adapter for AirTag is an adapter with a built-in programmer that allows access to data contained in the internal NOR memory of the GD25Q32. Our adapter simplifies reading the contents of the AirTag to a minimum - just remove the plastic cover and place the Air Tag in the module, insert the JIG into the adapter and connect it to USB to enable data reading.
Link: https://multi-com.eu/,details,id_pr,23154,key,atag-nor-adapter-for-airtag.html
MR TSOP56 adapter is a high-quality specialist adapter for reading TSOp48 chips using the NAND protocol without soldering. The MR TSOP56 Wide adapter is compatible with devices from companies such as Visual NAND Reconstructor, i.e. VNR (Rusolut), Flash Extractor (Soft Center) and PC3000 Flash (Ace Laboratory). In addition, the adapter has the option of configuring the TSOP56 pins called VSP (GND or VCC), which in some cases allows correct reading of the memory.
Link: https://multi-com.eu/,details,id_pr,23157,key,mr-tsop56-adapter.html
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
