 Post subject: New MR NAND eMMC Samsung adapter and new socket (pinout)
PostPosted: May 29th, 2025, 7:36
Hello guys,
We want to inform you about new products:
- adapter for eMMC / eMCP memory - MR TYPE 27 (Samsung BGA153) for support KLMBG2JETD, KLMAG1JETD and KLM8G1GETF
- Socket for eMMC NAND adapter - MR TYPE 7 PINOUT 5 to support SDIN8DR1-8G
More information you can find below:
MR NAND adapter for eMMC / eMCP memory - MR TYPE 27 (Samsung BGA153)
is high quality special adapter for eMMC flash memory using NAND protocol without soldering. The MR adapter is compatible with devices such as Visual NAND Reconstructor VNR (Rusolut), Flash Extractor (Soft Center) and PC3000 Flash (Ace Laboratory). The adapter replaces the need for any soldering to the card for reading and, thanks to unique solutions, it also provides quick analysis and configuration other pinouts using a logic analyzer. Use of the adapter minimizes the risk of flash chip damage by soldering (ie pad breaking) and instantly reading using various NAND programmers.
Supported eMMC chip:
Specification:
- made from solid monolith block of TecaFORM-H made in Germany and brushed aluminum for durability.
- printed circuit made with the highest precision of 4mils and gold plated pads to minimize interference
- specially developed PCB tracks routing technology to prevent interference during NAND reading
- special high quality pogo contact pins used which are used for specialized laboratory tests
- ready to work witch many pinouts by special sockets
- different cards size support by special inners
- built-in additional noise filters to prevent "noise" during NAND readings
- MR adapter can be connected to the SD card reader for initialization memory
- MR adapter can be connected to any LA (Logic Analyzer) to analyze signals and find custom pinouts without need of soldering
Compatible with devices of world leaders in data recovery:
- Visual NAND Reconstructor (VNR) - Rusolut
- PC3000 Flash (Ace Laboratory)
- Flash Extractor (Soft Center)
Supported models:
- KLMBG2JETD
- KLMAG1JETD
- KLM8G1GETF
Photos of the adapter:
Available socket (pinouts):
Photo of MR SD adapter mounted in Rusolut VNR
Photo of MR SD adapter mounted in PC3000 Flash - Monolith Board v4 and MultiBoard
Photo of MR SD adapter mounted in Flash Extractor
Complete contains:
- eMMC NAND Adapter - MR TYPE 27
- 1 socket (pinouts)
- 1 inners for positioning chip
- selected adapter for one of the listed devices ie VNR, PC3000 or FE (additional adapters can be purchased in addition)
- 1 SD card adapter for initialization memory
- 1 set of connection FF cables
- warranty card
More info: https://multi-com.eu/shrt-0uLmPTNe
Socket for eMMC NAND adapter - MR TYPE 7 PINOUT 5 is pinout for the eMMC NAND adapter that allowing to configure the MR adapter for the selected eMMC memory model. The product is available only to owners of the MR TYPE 7 adapter - when ordering, the serial number of the adapter will be required (the number is located on the adapter housing).
Supported memory:
- Sandisk SDIN8DR1-8G
Photo of assembled socket on adapter:
More info:https://multi-com.eu/shrt-IVOc2qQEp
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
