 Post subject: 500 GB seagate barracuda firmware 3.afd
PostPosted: December 29th, 2008, 2:45
My Lacia external drive has crashed and now I am trying to recover my data out of that disk.
500 GB seagate barracuda firmware 3.AFD
date code: 08051
Some one told TVS forum can help. Can someone please help me to find this PCB or guide me to recover data.
Thanks in Advance
Funtoosh
 Post subject: Re: 500 GB seagate barracuda firmware 3.afd
PostPosted: December 29th, 2008, 4:34
hi
how do you know that you have PCB problem
maybe just have some damaged on your Lacie Box
also you cant just swap the PCBs, u also need to swap Rom on pcb
i suggest you contact one of your local data recovery company if your data important to u
cheerss
PostPosted: December 29th, 2008, 5:07
hello,
i had PM you. please check. thanks. :)
data recovery service[/b]
PostPosted: December 29th, 2008, 8:28
Unlike you I am not a H/W guy. I took it to my friend and he did the investigation. He removed the HDD out of Lacia cabinet and tried to connect it as SATA drive . It was unable to detect. It was also making sound because earlier it feel out of my lap. So what my friend decided that take the similar kind of HDD and then mirror to get the data out of the drive. Is there any other way to recover the data ?
Thanks,
Funtoosh
ibcho wrote:
hi
cheerss
PostPosted: December 30th, 2008, 4:52
i am perrty sure that u dont have pcb problem
your hdd has head problem, it needs to be swapped it heads
and u cant do it yourself, as i told you b4; if your data important to u , u need to cantact your local data recovery company
otherwise u can try to swap head stack yourself just for fun and get some experince
good luck
PostPosted: December 30th, 2008, 5:03
Swapped the Head using which HDD? Smiliar config or any HDD will work?
