 Post subject: Where to purchase a PC-3000
PostPosted: January 26th, 2009, 2:49
I've been needing to purchase a PC-3000 for some time now. I believe the NA distributor that I spoke to a while ago had told me the cost is around $10,000. Is this true? Where can I find one for less expensive? I found this site selling one for $485. Is this legit? Here is the URL: http://www.pc3khrt.com/pc3Kpci.htm
 Post subject: Re: Where to purchase a PC-3000
PostPosted: January 26th, 2009, 6:09
Stay away from the rip-off chinese site, it's false economy buying it.
You pay for what you get, bear in mind you are probably getting English speaking support which is invaluable for a beginner.
Data Recovery Ireland
PostPosted: January 26th, 2009, 8:17
is it possible to retrieve data with PC-3000, even if i have fried PCB?!
PostPosted: January 26th, 2009, 12:20
Where could I get an authentic one for under a few thousand dollars? Thanks.
PostPosted: January 26th, 2009, 14:40
authentic PC-3000 is available at/thru PC-3000 distributors
www.datarecoveryne.com
PostPosted: January 26th, 2009, 16:07
Why don't you send the drive to a pro instead of trying to diy ? It will cost you much less
PostPosted: January 26th, 2009, 17:56
Did you try Frys Electronics or RadioShack?
