 Post subject: data RECOVERY FROM PCB BURN
PostPosted: April 29th, 2009, 6:45
I got sata WD800JD-00LSA0 DCM:HSBHNTJAH MOTOR #:1040-PUCOL
The pcb burn .I want to retrieve the data
I cannot find typical hdd .
What I got sata donor WD800JD-00MSA1 DCM:HSCHNTJCH MOTOR # :1040-TUCOR
Is any way to get the data using this donor hd
Thank you for your cooperation.
Sameer Batooq
 Post subject: Re: data RECOVERY FROM PCB BURN
PostPosted: April 29th, 2009, 8:05
Sameer Batooq
Yes, but you need to transfer the ROM from the burnt pcb to the another.
Janos
PostPosted: April 29th, 2009, 20:20
hi,
would you like to post models of both PCB.
data recovery service[/b]
