 Post subject: Need 5K100, hitachi
PostPosted: October 2nd, 2008, 21:57
HTS541040G9SA00,
MCL: DA130
FW: C60G
Looking for the pcb for this unit. whole hd is ok also, platter or head damage ok. willing to pay 50 plus for quick delivery. Make me an offer
hitachi 5k100, 40gb laptop drive, 5400 rpm
 Post subject: Re: Need 5K100, hitachi
PostPosted: October 3rd, 2008, 9:47
What are the 1st two lines of the sticker on the PCB?
Also, you do realise that you'll have to copy/move the NVRAM from the bad PCB to the donor, right?
Cheers
Sean
PostPosted: October 3rd, 2008, 16:41
0A26799
DA1189B
MzR613
H02N
, Oh, and this is a laptop hd.
also, you mentioned the nvram briefly, perhaps you could explain further? I assume identical firmwares will be sufficient.
thanks,
Dennis
PostPosted: October 3rd, 2008, 18:06
I'll check for that PCB on Monday for you.
Yes, I know it's a laptop drive! ;-)
Firmware match is NOT sufficient in these drives, the nvram points to a more-or-less unique position to pick up the SA (Service Area) and the Data Area.
So, you WILL require specialist tools or expert soldering skills to transfer this info to the new PCB.
If you're in/near UK, I can help you with this.
Cheers
Sean
PostPosted: October 3rd, 2008, 20:14
Well, I'm in Bermuda. we have soldering equipment, but what sort of specialist tools do you mean? will i need some sort of ic programmer? I've heard tell of something like that for the larger drives, but not for notebook drives. Is there some existing methodology for dealing with hitachis that I am unaware of?
Confusedly Yours,
Dennis
