| Wanted PCB For WD5000AAJS, Board# 2060-70144-004 Rev A http://forum.hddguru.com/viewtopic.php?f=15&t=10323 |
Page 1 of 1 |
| Author: | WillCertMyself [ October 30th, 2008, 0:41 ] |
| Post subject: | Wanted PCB For WD5000AAJS, Board# 2060-70144-004 Rev A |
I had a chip blow and need a replacement pcb Specs - M/N: WD5000AAJS-00YFA0 B/N: 2060-70144-004 Rev A MC IC: 88I6745-TFJ1 HDD MC IC: L6284 3.1 Plz Post if you have one and I will be notified and reply immediately Thanx Will |
| Author: | Mikippp [ October 31st, 2008, 11:37 ] |
| Post subject: | Re: Wanted PCB For WD5000AAJS, Board# 2060-70144-004 Rev A |
Hi, Usually this PCB has ROM embedded in CPU... If ROM is embedded in CPU... It is NOT possible to change PCB by the End User Mikippp |
| Author: | WillCertMyself [ November 23rd, 2008, 22:14 ] |
Well then if it does i can always find somewhere (in the middle of nowhere) with micro soldering capibilaties to replace the chip, (Obviously a half empty, ehh?) anyways heres those pics of it. |
| Author: | networkpc3000 [ November 25th, 2008, 2:20 ] |
hello, i have. please contact me if you need. thanks |
