| Important info for matching donor drives http://forum.hddguru.com/viewtopic.php?f=15&t=10585 |
Page 1 of 1 |
| Author: | simon [ November 27th, 2008, 21:01 ] |
| Post subject: | Important info for matching donor drives |
Hi, Can anyone tell me what the important information is for Western Digital Drives. I assume the model number, size etc. They also have a dcm number and an mdl etc. What is the relavent info you must match up to find a donor drive. The one I have is: MDL WD5000AAKS-00YGA0 DCM HBRNNT2CHN 500 Gig WWN 50014EE1AB43DDB5 S/N WCAS84313792 Any help appreciated. thanks.. simon |
| Author: | craig6928 [ November 27th, 2008, 22:47 ] |
| Post subject: | Re: Important info for matching donor drives |
MDL WD5000AAKS-00YGA0 DCM HBRNNT2CHN DATA REV The model number and extension all these have to be the same allso turn the drive over you will see a white bar code 14 numbers those numbers have to match too. not sure but i think you could swap the ROM chip over. but the qeastion is what type of problem are you having with the drive in the first place. |
