 Post subject: i think i need new pcb board for st3640323as
PostPosted: November 29th, 2008, 9:34
i think i need new pcb board for st3640323as Tried new sata-usb adapter, board started
smoking & burned 2 of power tabs. Installed board from newer sgt 640 gb drive I had on hand with different firmware (orig SD13 vs new SD35)( before finding this forum, newbie on hd's ), received i/o error
disconnected "immediately" and put board back on empty drive I took it from and that drive is ok.
Drive has 550 gb data on it, was going to back it up to new 640 gb drive ( the one I took board from )
Hopefully, changing board will fix original drive.
defective drive info...
ST3640323AS
P/N 9FZ134-300
FIRMWARE SD13
reverse side white tag info
1005125B5 D 7848PML
PLS e-mail me at dhsvcs@aol.com
 Post subject: Re: i think i need new pcb board for st3640323as
PostPosted: November 29th, 2008, 10:30
"Just" changing the PCB will NOT work on this drive, trust me. No matter how close a match you get.
The ROM on the board is unique to the drive.
I tested this with two IDENTICAL known good drives from a RAID 0 configuration. Swapped the boards, no go. Until I moved then ROM's. Then they both worked again.
Also, if you connect the PCB alone to test equipment (e.g. Salvation) the drive reports it's model number, f/w version and serial number.
