 Post subject: Wanted: Barracuda 7200.9 300GB
PostPosted: November 5th, 2008, 3:37
I had this hard drive set aside for some time but it worked before I took it out. It shows up in BIOS but not windows. It clicks repeatedly on regular (and fast) intervals. I'm looking for advice or an identical drive to swap parts from. I'm also wondering if I would be able to do this myself or if someone here would take my cash in exchange for their services.
I only want it alive long enough to mirror the data.
S/N: 5NF24KYB
ST3300622AS
P/N: 98D144-304
Firmware: 3.AAH
Date Code: 06442
Site Code: WU
Thanks for the help.
Edit: I found one on eBay. Should I buy it?
 Post subject: Re: Wanted: Barracuda 7200.9 300GB
PostPosted: November 5th, 2008, 3:46
We can only advise for this drive if you post here the terminal log.
You can find in other posts how to do that.
Dobre
Murphy was an optimist
PostPosted: November 5th, 2008, 4:44
If it's een in the BIOS, but clicking, 99% certain you have at least one bad bad head(s).
The good news is that the SA is almost certainly OK, if it's seen correctly in BIOS. Heads need to be changed.
You will not be able to do this on your own (assuming you don't have a clean room, head change tools and years of DR expernience). I have done loads of these.
I can help if you're willing to ship to UK?
PM me if interested.
Cheers
Sean
PostPosted: December 29th, 2008, 22:50
Gorbachev, I sent you a PM about the drive. I have the exact same one. Please respond.
Users browsing this forum: No registered users and 6 guests
