 Post subject: Fujitsu MHT2060AH Drive PCB
PostPosted: January 10th, 2009, 21:51
I need the PCB for a Fujisu MHT2060AH model drive. The board must have a software version 027A - 006C.
 Post subject: Re: Fujitsu MHT2060AH Drive PCB
PostPosted: January 12th, 2009, 5:32
I have only 02AE-006C.
Does it fits you?
PostPosted: February 9th, 2011, 8:57
Do you still have this particular board? I would be rather interested. Thanks.
PostPosted: February 9th, 2011, 21:43
would you like to show images of your PCB? need PCB or firmware?
data recovery service[/b]
PostPosted: February 10th, 2011, 0:50
Does the drive spin up? If not, did you check the fuse near the end pins of the IDE connector?
