| Fujitsu MHT2060AH Drive PCB http://forum.hddguru.com/viewtopic.php?f=15&t=10954 |
Page 1 of 1 |
| Author: | jwratts [ January 10th, 2009, 21:51 ] |
| Post subject: | Fujitsu MHT2060AH Drive PCB |
I need the PCB for a Fujisu MHT2060AH model drive. The board must have a software version 027A - 006C. |
| Author: | dmarques [ January 12th, 2009, 5:32 ] |
| Post subject: | Re: Fujitsu MHT2060AH Drive PCB |
Hi, I have only 02AE-006C. Does it fits you? |
| Author: | richinnewzealand [ February 9th, 2011, 8:57 ] |
Do you still have this particular board? I would be rather interested. Thanks. |
| Author: | networkpc3000 [ February 9th, 2011, 21:43 ] |
would you like to show images of your PCB? need PCB or firmware? |
| Author: | fzabkar [ February 10th, 2011, 0:50 ] |
richinnewzealand wrote: Do you still have this particular board? Does the drive spin up? If not, did you check the fuse near the end pins of the IDE connector? |
