Wanted-WD2500KS -OOMJBO Logic Board
http://forum.hddguru.com/viewtopic.php?f=15&t=11240
Author:  BuellFool [ February 8th, 2009, 16:27 ]
Post subject:  Wanted-WD2500KS -OOMJBO Logic Board
Need Board with DCM of HSCHCTJAAN.
Date of/around 16 Jan 2007. :cry:
Author:  harddrivespecialist [ February 8th, 2009, 21:02 ]
Post subject:  Re: Wanted-WD2500KS -OOMJBO Logic Board
Full model number and a PCB number would help you and us better.
Author:  BuellFool [ February 8th, 2009, 21:26 ]
MDL : WD2500KS-00MJB0
WD Caviar SE16
S/N WCANK592810
Board # 2060-701335-005 REV A
Got replacement board from Softcon, but bios chip is different.
Get Hawk...error msg.
Maybe barking up wrong tree, but I inadvertently had both power supply plugs hooked up when I booted up. So, I thought I'd try a new circuit board to resurrect old HDD, and recover data.
Any ideas ?.. Thx..
Author:  rameez [ February 9th, 2009, 14:10 ]
You can change the ROM chip from your old pcb to then new one , that will make your new pcb compatible with your drive .
The ROM chip is indicated on the pcb as U12 on most wd drives .
