WD1600AAJS-00B4A0 PCB NEED OR REPAIR IT
http://forum.hddguru.com/viewtopic.php?f=15&t=11423
Author:  zebong [ February 25th, 2009, 9:16 ]
Post subject:  WD1600AAJS-00B4A0 PCB NEED OR REPAIR IT
Need this PCB
Or way to repair it when i connect the PCB i have the ATA Error: ERR / ABRT
ZeBong
Author:  Mikippp [ February 25th, 2009, 9:32 ]
Post subject:  Re: WD1600AAJS-00B4A0 PCB NEED OR REPAIR IT
PCB is damaged... are U sure...?
Mikippp
Author:  zebong [ February 25th, 2009, 9:36 ]
Yes i am sure i make a hotwap
yes with other PCB the drive get DRD DSC.
It´s not 100% compatible because the model is the same wd1600aajs-xxxxxx ( this are different)
i try a hotswap, and i can test heads 100% ok.
Author:  zebong [ February 26th, 2009, 9:43 ]
Mikippp
Hi Mikippp,
You are right :) is not PCB problem.
Need ROM or the FW for this disk ?
Can you please see if you have it to share with me.
Ze
Author:  Mikippp [ February 26th, 2009, 12:47 ]
Pinnacle ROM
Mikippp
Author:  zebong [ February 26th, 2009, 12:48 ]
Yes the disk is from the Family Pinnacle.
Ze
Author:  networkpc3000 [ February 27th, 2009, 9:07 ]
i have
Author:  zebong [ February 28th, 2009, 13:43 ]
Mikippp wrote:
Pinnacle ROM
Mikippp
Author:  xjhal7101 [ March 8th, 2009, 9:24 ]
rewrite ROM
