Page 1 of 1
Need a SMD Diode for my WD2500AAJS HDD
Posted: February 26th, 2009, 2:13
by liferocks
Hi, I'm new to this forum.
Please help me with a component problem on my WD2500AAJS HDD.
MDL: WD2500AAJS-00YFA0
DATE: 22 JAN 2008
DCM: DHRNNT2CHN
S/N WCASE0196146
PCB Details PWB 2060-701444-004 REV A
A diode in the supply section labeled D3 is burnt out. I can't even read its no. If anyone can provide me the exact no. of that diode or better an equivalent that is avlbl as spare or best the complete card, it'd be awesome man.
Thanx in advance.
The State of your Life is Nothing more than a Reflection of your State of Mind!!
Re: Need a SMD Diode for my WD2500AAJS HDD
Posted: February 26th, 2009, 2:16
by liferocks
I got very important data from my Recording Studio on that HDD.
There's no OS on that drive, i was just using it as a data backup drive.
Any help would be greatly appreciated.
Posted: February 26th, 2009, 2:25
by liferocks
Also, I'm not very sure, if I can simply replace the PCB from another same model HDD. Do I need to change any other SMD component so that it can function properly with my HDD.
In case I can get the SMD component Diode D3, then I'll not need to replace anything at all besides that. Else I'm not very sure what all components result in the compatibility of the PCBoard with the HDD unit.
Posted: February 27th, 2009, 9:03
by networkpc3000
hello,
i have this PCB. please contact me if you need it from me. sunnydreamspace@hotmail.com. thanks.
Posted: October 11th, 2010, 3:09
by liferocks
Hey networkpc3000
My bad luck again!
The same HDD has a burnt SMOOTH chip now.
Actually I had got the diode D3 replaced from some computer repair guy who assured that it'd work fine. I took it from him and checked, it was working fine. But I guess he simply replaced it with not the exact diode and which might have caused some kind of problem in the long run leading to the SMOOTH chip getting burnt out.
So I was wondering if you still have the PC board No. PWB 2060-XXXXXX-XXX
I can manage replacing the main processor chip. Can't replace the smooth chip as the track below also seems to have burned out.
Anybody else, pls if you have this board I'd like to buy it from you.
Any help is sincerely appreciated.
Keep Rocking All of you.
Posted: October 11th, 2010, 23:42
by networkpc3000
hi,
have it in stock. and you'd better replace smooth instead of replace MCU(if possible. some case smooth part burned too much). as it more easy to do that. please feel free to contact me by email or MSN if need. thanks.
Posted: October 12th, 2010, 0:17
by Eric Lee
Hi, We have this working PCB in stock too, pls contact my hotmail to see if I can help or not.
Eric
Posted: October 13th, 2010, 19:54
by fzabkar
A straight board swap won't work. You need to transfer the "adaptive" data from patient to donor. I believe that your board stores these data within the Marvell MCU. Otherwise look for an 8-pin chip at location U12, if it exists.
BTW, check your power supply. The TVS diodes fail when subjected to overvoltages.
Posted: October 15th, 2010, 6:03
by liferocks
Thanx for your advice fzabkar.
I am slightly confused about your saying that a straight board transfer won't work.
What I'm trying to do is de-solder the Marvell MCU from the patient PCB and solder it on to the donor PCB that has a working SMOOTH chip and all other components.
Will that work? Or do I have to transfer only the data from the patient MCU to the donor MCU without de-soldering/re-soldering any of the MCUs?
In my case the U12 chip doesn't exist on the card.
And Im not using a HDD casing with the HDD. Actually, I have a SATA HDD with a USB/IDE-SATA converter cable and it works absolutely fine with other drives too. However, I suspect some kind of sparking or prolonged use of the HDD with improper heat convection.
Posted: October 15th, 2010, 21:29
by fzabkar
If the MCU has survived, then transplanting it to the donor should work, assuming that the preamp inside the HDA is OK.
However, if you can transfer the MCU's adaptive data, then that would be a much better solution.
Try the following vendor:
http://www.hdd-parts.com/firmware-transfer.html
They offer a PCB plus firmware transfer service for between US$50 and US$70.
Posted: October 19th, 2010, 18:04
by networkpc3000
i don't think swap MCU will stable solution for this case. i can help rebuild PCB adapter data from hard drive even it without original PCB.
Posted: November 15th, 2010, 1:15
by liferocks
@fzabkar
Where can I get only the SMOOTH chip? Could you suggest some vendor or a link to the vendor.
I think It'd be more sensible to replace only the burnt SMOOTH chip.
Thanx \m/
Posted: November 15th, 2010, 11:45
by lcoughey
If your time is of any value to you, it would be cheaper and less destructive to your data to just send the drive to a data recovery professional. Each time you fry out the PCB, the heads are likely being slammed into the platters, causing other issues. With the right tools, a data recovery professional could have your data recovered in a day or two for less than $1000, assuming that there is minimal internal damage.
Good luck.
Posted: November 21st, 2010, 2:27
by fzabkar
liferocks wrote:Where can I get only the SMOOTH chip?
I suspect that it may be easier to get a complete PCB than the SMOOTH chip on its own. Consider also that the SMOOTH chip controls the DC-DC converters which may themselves have failed.
Posted: November 23rd, 2010, 2:26
by liferocks
Ya, Thank u guys for your advice.
\m/
