 Post subject: WD1600AAJS-00B4A0 PCB NEED OR REPAIR IT
PostPosted: February 25th, 2009, 9:16
Need this PCB
Or way to repair it when i connect the PCB i have the ATA Error: ERR / ABRT
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: WD1600AAJS-00B4A0 PCB NEED OR REPAIR IT
PostPosted: February 25th, 2009, 9:32
PCB is damaged... are U sure...?
Mikippp
PostPosted: February 25th, 2009, 9:36
Yes i am sure i make a hotwap
yes with other PCB the drive get DRD DSC.
It´s not 100% compatible because the model is the same wd1600aajs-xxxxxx ( this are different)
i try a hotswap, and i can test heads 100% ok.
ZeBong
" Россия еще раз"
PostPosted: February 26th, 2009, 9:43
Mikippp
Hi Mikippp,
You are right :) is not PCB problem.
Need ROM or the FW for this disk ?
Can you please see if you have it to share with me.
Ze
ZeBong
" Россия еще раз"
PostPosted: February 26th, 2009, 12:47
Pinnacle ROM
Mikippp
PostPosted: February 26th, 2009, 12:48
Yes the disk is from the Family Pinnacle.
Ze
ZeBong
" Россия еще раз"
PostPosted: February 27th, 2009, 9:07
i have
data recovery service[/b]
PostPosted: February 28th, 2009, 13:43
Mikippp wrote:
Pinnacle ROM
Mikippp
ZeBong
" Россия еще раз"
PostPosted: March 8th, 2009, 9:24
rewrite ROM
