| Wanted!!! PCB Seagate Barracuda 500Gb 7200.11 Firmware SD25 http://forum.hddguru.com/viewtopic.php?f=15&t=11580 |
Page 1 of 1 |
| Author: | muttsnuts [ March 13th, 2009, 9:58 ] |
| Post subject: | Wanted!!! PCB Seagate Barracuda 500Gb 7200.11 Firmware SD25 |
Hi I am looking for a controller board for a Seagate HDD with specific firmware. If anybody knows of another suitable board that I can use then I will try that as well. Thanks Jon |
| Author: | pcimage [ March 13th, 2009, 15:48 ] |
| Post subject: | Re: Wanted!!! PCB Seagate Barracuda 500Gb 7200.11 Firmware SD25 |
Why do you want this? What's actually wrong with the drive? 7200.11 PCB's are unique, even the serial number of the drive is programmed into the ROM. Even if you find a PCB with the same FW version, it still will not work. I'm in England and can help if you want at a token price. PM me if interested. Sean |
