| *Urgent* Seagate ST9120822AS needed http://forum.hddguru.com/viewtopic.php?f=15&t=12096 |
Page 1 of 1 |
| Author: | ParaMagnetic [ April 28th, 2009, 12:21 ] |
| Post subject: | *Urgent* Seagate ST9120822AS needed |
Looking for a Seagate drive: Model: ST9120822AS FW: 3.CAE Data:8021 Site:WU Here is the catch: it's from an apple notebook, so I need the Apple code to match as well: VEN-S 655-1327B *JY72716KRXRJA* I am not as familiar with the apple codes, but i think all that is need is the "655-1327B" If you have a drive please let me know asap as this is an urgent case |
| Author: | pcimage [ April 28th, 2009, 15:32 ] |
| Post subject: | Re: *Urgent* Seagate ST9120822AS needed |
3.CAE = 7.01 = sh1t |
| Author: | ParaMagnetic [ April 28th, 2009, 17:45 ] |
indeed! No visible rings on this drive; so i believe the problem is actually heads which is what I am attempting to replace. Donor I received had heads stuck to platters on opening! Removed heads from platter, and attempted swap anyways (since i could already not return the drive) no luck, still "click click *pause* click click *pause* head mask ffff |
| Author: | Steve [ April 28th, 2009, 18:45 ] |
ParaMagnetic wrote: indeed! No visible rings on this drive; so i believe the problem is actually heads which is what I am attempting to replace. Donor I received had heads stuck to platters on opening! Removed heads from platter, and attempted swap anyways (since i could already not return the drive) no luck, still "click click *pause* click click *pause* head mask ffff Why would you open a donor without first testing it to see if it works? |
| Author: | ParaMagnetic [ April 29th, 2009, 12:45 ] |
I did =) Drive worked great; spun down, then powered off. Go to open it up to transfer heads, and what do you know....heads are on the platter. Not just alittle stuck either. VERY stuck. Bad luck I guess.... |
