data RECOVERY FROM PCB BURN
http://forum.hddguru.com/viewtopic.php?f=15&t=12106
Author:  redseaksa [ April 29th, 2009, 6:45 ]
Post subject:  data RECOVERY FROM PCB BURN
I got sata WD800JD-00LSA0 DCM:HSBHNTJAH MOTOR #:1040-PUCOL
The pcb burn .I want to retrieve the data
I cannot find typical hdd .
What I got sata donor WD800JD-00MSA1 DCM:HSCHNTJCH MOTOR # :1040-TUCOR
Is any way to get the data using this donor hd
Thank you for your cooperation.
Sameer Batooq
Author:  N.C. [ April 29th, 2009, 8:05 ]
Post subject:  Re: data RECOVERY FROM PCB BURN
Sameer Batooq
Yes, but you need to transfer the ROM from the burnt pcb to the another.
Janos
Author:  networkpc3000 [ April 29th, 2009, 20:20 ]
hi,
would you like to post models of both PCB.
