 Post subject: Wanted Maxtor 6H500F0 500GB with Firmware HA421DD0
PostPosted: April 30th, 2009, 14:22
Deparately need donor drive for recovery on Maxtor 6H500F0 500GB with Firmware HA421DD0.
Please contact me if you have for Sale.
Thank you...
Stephen
 Post subject: Re: Wanted Maxtor 6H500F0 500GB with Firmware HA421DD0
PostPosted: May 2nd, 2009, 23:58
Dear Stephen,
would you like to let me know what you have to match for it? keep in touch by email. thanks.
data recovery service[/b]
PostPosted: May 3rd, 2009, 11:25
What do you want from the drive PCB or heads ?
PostPosted: May 3rd, 2009, 12:15
I have to admit I am new to drive recovery, but learning quickly. I have the Maxtor HD Doctor from salvationdata. If I understand correctly my heads and PCB are good but the firmware on the platters is damaged and I need an exact match donor with the firmware HA421DD0 to use on my patient drive and get the data back.
So ideally a whole working drive is best but a drive with a failed PCB might still be useful to me. Someone with more skills would probably have a better way, but for me it is a learning process!
Thanks for the reply..Stephen
PostPosted: May 3rd, 2009, 12:35
In this way, you will lear how to loose your data. :(
Read this instead:
results-the-yourself-solutions-t11912.html?hilit=results
Janos
PostPosted: May 3rd, 2009, 17:07
Thanks Janos... I totally respect that and I did read the newbie files. Actually I am getting proper training and working with a professional. I don't do anything on any drive without his approval. They tell me in the case of this drive - a perfectly matched donor is the best chance of recovery... Guess we'll see :?
PostPosted: May 3rd, 2009, 17:33
Ok, let me see....
Wich modules do you need?
(As far as i know / based on my experience the 90% of the maxtor cases not need "donor" for SA repairing.
A good engineer can repair the damaged SA by itself, or can recalculate/rebuild the missing modules without external resources.)
Janos
PostPosted: May 4th, 2009, 12:26
Hi, Stephen
we are specialize in selling HDD PCBs, pls keep in touch my mail. eric_lee8341@hotmail.com , you could search "HK Mingdi" in google, then you will find our company information. There also have our repairing room picture in our website.
TKS!
Providing HDD PCBs and donor HDDs, Real in stock.
WhatsApp: +8613480790845
