WTB: WD3200BEVT-22ZCT0
http://forum.hddguru.com/viewtopic.php?f=15&t=12298
Author:  pcrecovery [ May 20th, 2009, 21:32 ]
Post subject:  WTB: WD3200BEVT-22ZCT0
Donor needed for heads
DCM: HANTJAB 2p 4h
Have several of these (new) in my inventory (both are xxxx2Axx, HANT2ABB, etc). Happy to trade with fellow DR business/pro or purchase.
Thanks for checking.
Author:  jockoboy [ August 11th, 2009, 16:56 ]
Post subject:  Re: WTB: WD3200BEVT-22ZCT0
I have DCM DHCTJHBB if it helps ...
AND any chance you have still have these -22ZCT0 .. I am in need of a copy of the ROM. Can you help me?
regards, DF
Author:  drc [ August 11th, 2009, 17:40 ]
http://files.hddguru.com/index.php?acti ... 20Digital& has a ROM for that model in it.
Author:  pcrecovery [ August 11th, 2009, 20:41 ]
Just make ROM from SA .
Author:  jockoboy [ August 12th, 2009, 12:44 ]
I have a PC3000 only. Is that ROM file useable on the PC3000?
OR regarding making a ROM from the SA ... how can I do that?
thanks again
Author:  drc [ August 12th, 2009, 13:16 ]
The ROM is a binary file, it shouldn't matter what you use with it.
Like pcrecovery is alluding to, its not going to do you much good though as the ROM on these drives is individualized to the drive. If you have PC3000UDMA then it should provide the procedure for recreating the SA.
