Please help with PCB (2061-701477-100 04P) for WD5000AAJS
Posted: June 12th, 2009, 14:27
by REMONYOUSIF
I have a WD5000AAJS external 500 GB drive that it needs a new board. It spins for short time when I hook it up to my PC but it turns off afterwads, I took it to some data recovery places and they found that I need to replace the PCB which is burned. Please help to find a PCB similar to what I have.
Spec:
Western Digital: 500 GB WD Caviar SE
Model WD5000AAJS-32vfa0
Date: 10 Jan 2008
PCB Model Number:
2061-701477-100 04P
YOUSIF
yousif_remon@yahoo.com
Re: Please help with PCB (2061-701477-100 04P) for WD5000AAJS
Posted: June 12th, 2009, 15:41
by N.C.
PCB swap on this model not helps, because have configuration chip or embeded ROM in MCU.
If you need the data, i suggest to find a pro close to you....
Some info, about why not try to replace the pcb:
results-the-yourself-solutions-t11912.htmlJanos
Posted: June 12th, 2009, 23:44
by Eric Lee
Hello, YOUSIF
I agree with Janos, Rom programmer of this model was in the Main chip, pls find a pro near you.
N.C. wrote:PCB swap on this model not helps, because have configuration chip or embeded ROM in MCU.
Eric
Posted: June 13th, 2009, 6:19
by Mikippp
I can help...
PS I'm near you
Mikippp
Posted: June 13th, 2009, 10:13
by pcimage
Agree, you definitely need a pro for this particular case. If it was a previous model with an external ROM chip then yes you may well have been able to do it yourself with our help. In any case it doesn't actually sound like a PCB problem if it spinning up then down, more like heads.
You can trust mikippp, he knows what he's doing.
Posted: January 3rd, 2012, 7:07
by Wolf99
Hello and sorry for conjuring this post from the dead.
I have the same situation, and I read the thread and did not understand something.
I have a WD5000AAJS-22TKA0 HDD with a small burnt chip on the pcb,
It shows the same symptoms, it spins up and then stops.
Why wouldn't a suitable PCB replacement do the trick with this model? would trying to solder a similar new one from another HDD work?
And what method do professional labs would take to get the data out?
Thank you,
Wolf99
Posted: January 3rd, 2012, 10:04
by Tawfeek
you can use the popular 701444 PCB instead of 701477 if you have tools can reprogram the MCU like pc3k or wd doctor or some thing like that
Posted: January 3rd, 2012, 16:19
by fzabkar
Wolf99 wrote:I have a WD5000AAJS-22TKA0 HDD with a small burnt chip on the pcb,
There is a cheap tool (WDR-UDMA or WD HD Pro, US$80 - $150) that should enable you to reprogram a replacement PCB. However, it may be that your drive has an internal fault.
Could you upload a photo of the PCB, particularly in the area of the burnt chip?
