 Post subject: WTB: Hitachi Deskstar 82.3gb HDS728080PLAT20 0A30290 PCB
PostPosted: June 13th, 2009, 13:29
Really, Really need this. Hope someone has the PCB. FedEx badly damaged a computer that my sisters computer and the legs on the large chip on the pcb got dinged. She just had her first baby and had all of her pictures on it along with some important family files. She wasn't very smart and didn't backup anything.
Drive is a Hitachi Deskstar 82.3gb
Model: HDS728080PLAT20
Jul-2004
P/N/: 0A30290
MLC: BA1116
Big chip on PCB says:
Infineon
0A30164
UAB-M3057-HT
V3.3
FRKRSI
Label by pcb says: 0A30417 BA1085A XFK427 1L03
 Post subject: Re: WTB: Hitachi Deskstar 82.3gb HDS728080PLAT20 0A30290 PCB
PostPosted: June 13th, 2009, 13:57
What do you plan on doing with it if you get one?
PostPosted: June 13th, 2009, 14:03
Was hoping to swap the pcb just to get the data off unless it's not possible.
PostPosted: June 13th, 2009, 14:39
not possible without nvram transfer. these drives have pretty much unique info programmed into a chip on the pcb. u need pro help for this one my friend.
PostPosted: June 13th, 2009, 14:51
Ok. Well who do you recommend. I cant solder and asume you have to swap the chip to a different board, correct?
PostPosted: June 13th, 2009, 15:21
easier (for pro) to read out the old nvram, or rebuild a new one from the sa (service area)
I don't know who's the nearest pro on here to you.
Any takers guys?
PostPosted: June 14th, 2009, 18:53
Found a match locally. Can I just swap boards for a bit to get a little information off without transfering the nvram or will the board burn up
PostPosted: June 14th, 2009, 20:10
If it doesn't work, it doesn't work. It's not going to work for a minute or two and then burst into flames.
PostPosted: June 15th, 2009, 14:44
99% won't work.
I say 99% because once I found two VLAT drives that worked with the same PCB :shock:
PostPosted: June 15th, 2009, 20:58
Hello I have the drive that you have recently made a successful recovery of data with one identical to your hard disk if you wish please contact me, I'm in Brazil
Luiz
