HDD GURU FORUMS
http://forum.hddguru.com/
NEED WD WD2000JB-00GVA0 & Seagate ST31000340AS FW:SD14 PCBs
http://forum.hddguru.com/viewtopic.php?f=15&t=12925
Page 1 of 1
Author:  acidann [ August 5th, 2009, 3:07 ]
Post subject:  NEED WD WD2000JB-00GVA0 & Seagate ST31000340AS FW:SD14 PCBs
Hi my hard drives PCB board got burned up becoz of the power problem (yes burned two HDs at once ><)
but the PCB board for WD HD is hard to find on the web~
So I would like to know if anyone has these 2 PCBs please let me know.
Here are my HDs info:
WD Caviar SE P/N: WD2000JB-00GVA0
Seagate ST31000340AS P/N: 9BX158-302 Firmware: SD14
Thanks a lot!!
Author:  Eric Lee [ August 5th, 2009, 7:47 ]
Post subject:  Re: NEED WD WD2000JB-00GVA0 & Seagate ST31000340AS FW:SD14 PCBs
Would you like to send me the high quality pic of both side of your PCBs so that we could match what you need ?
Eric
Author:  pcimage [ August 5th, 2009, 11:20 ]
Both these drives will require a ROM transfer also.
Author:  networkpc3000 [ August 6th, 2009, 2:26 ]
hi,
i have for sell. would you like to provide images to me by email? thanks.
http://www.phpbb.com/
