Looking for Hitachi Travelstar HTS548080M9AT00 Harddrive
Posted: August 11th, 2009, 0:02
by omer
I am looking for this exact Hard drive. This is a rare hard drive to find. Notice that I circled the pin connectors.
Model: HTS548080M9AT00
P/N: 08K0858
Re: Looking for Hitachi Travelstar HTS548080M9AT00 Harddrive
Posted: August 11th, 2009, 0:47
by harddrivespecialist
What do you need a drive for?
Posted: August 11th, 2009, 2:20
by drc
FYI, that connector pulls straight off.
Posted: August 11th, 2009, 4:24
by omer
drccsc wrote:FYI, that connector pulls straight off.
REALLY? If that's the case...Thank you so much Drccsc! I've been helping my friend find a HD that works with his DELL XPS Generation 1 Laptop.
Thank you!
Posted: August 11th, 2009, 17:57
by pcimage
Yep, that's an adaptor to connect the regular 44-pin connection to the edge connector in the laptop.
Posted: August 11th, 2009, 23:10
by omer
pcimage wrote:Yep, that's an adaptor to connect the regular 44-pin connection to the edge connector in the laptop.
thank you thank you thank you. Problem solved!
Posted: September 4th, 2009, 12:11
by vicand3boys
If I can't find the exact one, which ones are compatable? I don't want to spend a lot of $. Used OK
