| Looking for PCB WD7500AACS-00D6B0 http://forum.hddguru.com/viewtopic.php?f=15&t=14802 |
Page 1 of 1 |
| Author: | IDeathI [ February 10th, 2010, 12:45 ] |
| Post subject: | Looking for PCB WD7500AACS-00D6B0 |
MDL: WD7500AACS-00D6B0 Date: 29 OCT 2008 PCB: 2016-701537-R00 AD XC 6Q05 1XLS K 0004170 9174 Maker: Thailand DCM: DHRNHT2CAB SN: WCAU44238989 If there is a donor pcb, would it require to have a ROM switch? If so then I'll take it to a computer technician to do that. |
| Author: | pcimage [ February 10th, 2010, 13:47 ] |
| Post subject: | Re: Looking for PCB WD7500AACS-00D6B0 |
Sorry to say that your computer technician will not be able to switch the ROM on this PCB. The PCB on theis series on WDd drives do contain adaptive (virtually unique) info in the ROM, but it's inside the MCU so you need specialist hardware and software to do this. |
| Author: | IDeathI [ February 10th, 2010, 13:51 ] |
Ah, o well I guess it was worth a try. I might as well purchase another HDD. |
| Author: | networkpc3000 [ February 12th, 2010, 7:57 ] |
hi, i have this PCB in stock. and i can help you program data into PCB too. please contact me by email if still need help. thanks. |
| Author: | Eric Lee [ February 13th, 2010, 3:11 ] |
Hi, We have this working PCB in stock, and you are correct, rom swap is needed. Pls contact my hotmail to see if I can help. Thanks Eric |
