 Post subject: SATA LED Activity
PostPosted: January 29th, 2020, 10:57
Hello guys,,,
Am doing some research which requires mainly Knowing SATA Packets (Sent/Received) to cut it short am looking for the following:
LED Indicator (per SATA Cable/Drive) which tells me (Blinks) when the action is now on that particular drive for example...
Is there any ready SATA cable with such LED indicator option? (looks not so far)
Is there any way to Make one (DIY)?
Thank you
 Post subject: Re: SATA LED Activity
PostPosted: January 29th, 2020, 13:21
Even better
http://www.myportablesoftware.com/freehddled.aspx
this should be enough
