HDD GURU FORUMS
http://forum.hddguru.com/
Looking for PCB board for WD2500KS
http://forum.hddguru.com/viewtopic.php?f=15&t=14975
Page 1 of 1
Author:  orion3999 [ February 28th, 2010, 17:31 ]
Post subject:  Looking for PCB board for WD2500KS
i am looking for a PCB board for a Western Digital WD2500KS
MDL:WDS2500KS-00MJB0
DCM:DSCANTJAA
Board:2061-701335-C00
i will take any board that will make this drive work. i am trying to recover data. if you have a board that will work, please provide location of proof, so that i may confirm.
Author:  networkpc3000 [ February 28th, 2010, 19:30 ]
Post subject:  Re: Looking for PCB board for WD2500KS
hi,
i have this PCB in stock. please contact me by MSN or email. thanks.
Author:  fzabkar [ February 28th, 2010, 22:54 ]
Can you upload a detailed photo of the component side?
What is the failure symptom?
Author:  orion3999 [ March 1st, 2010, 11:20 ]
not detected in bios. no sound of drive spinning up.
Author:  networkpc3000 [ March 1st, 2010, 19:45 ]
take off PCB and have a look. SMOOTH chip may burned already. 8)
Author:  orion3999 [ March 2nd, 2010, 21:46 ]
here is a pic of the board and the top of the drive.
the full number on the bottom of the drive is
2061- 701335-C00 AG XC 2W130N8S B 0004400 6404
File comment: board is burned bottom left
File comment: top of drive
Author:  fzabkar [ March 2nd, 2010, 22:16 ]
Your motor controller chip is damaged.
You will probably need to transplant the 8-pin serial EEPROM chip at location U12 from patient to donor. This is because it stores unique drive calibration data.
Author:  orion3999 [ March 3rd, 2010, 0:50 ]
wont i be able to just swap in a new board?
Author:  pcimage [ March 3rd, 2010, 4:18 ]
No, you need to transfer U12 also.
http://www.phpbb.com/
