Page 1 of 1
Wanted: Multiple Western Digital drives
Posted: March 17th, 2010, 13:17
by cheadledatarecovery
Hello there,
I have a number of hard disk drives that I require, it is for a mixture of PCB, firmware & head assembly failure. Needless to say they are all WDs. Some I require the full drive, some I require just the PCB (although complete drive preferred). I also have a extensive selection of drives should any other DR companies be looking to do some swaps.
Any one out that can help?
Best wishes,
John
Full drive or PCB
MDL: WD2500JS-xxNGB2
PCB: 2060-701335-005 REV A / 2061-701335-B00 AF
Spindle: 1024 CAFFF
Full drive or PCB
PN: WD1200BB-xxGUA0
PCB: 2060-701266-001 REV A / 2061-701266-200 AG
Spindle: 1024 CAFFF
Full drive (I only require this drive for a few firmware modules, so fewer parameters required for match)
PN: WD800UE-xxKVT0
LBA: 156301488
Full drive
WD2500JB-xxREA0
DCM: HBBANT2CAN (NT2) critical
Serial No to start: WCANKD
Full drive
Model No : WD2500BB-xxGUC0
Serial No : WCAL
DCM: HSCHCVJAA
Spindle: 1024-TAFON
Re: Wanted: Multiple Western Digital drives
Posted: March 17th, 2010, 13:40
by Amarbir[CDR-Labs]
cheadledatarecovery wrote:Hello there,
Best wishes,
John
Full drive or PCB
Spindle: 1024 CAFFF
Full drive or PCB
PN: WD1200BB-xxGUA0
Spindle: 1024 CAFFF
PN: WD800UE-xxKVT0
LBA: 156301488
Full drive
WD2500JB-xxREA0
Full drive
Serial No : WCAL
DCM: HSCHCVJAA
Spindle: 1024-TAFON
sir ,
If You Like PCB Try Mr Lee
Posted: March 17th, 2010, 13:44
What a catchy tag line. I am familiar with Eric, he's on the case at the moment and has some PCBs that are close to the ones I want. I am always overly cautious on WD PCB replacements when it comes to getting an exact match though, as I am sure you understand.
Thanks,
John
Posted: March 17th, 2010, 13:51
cheadledatarecovery wrote:What a catchy tag line. I am familiar with Eric, he's on the case at the moment and has some PCBs that are close to the ones I want. I am always overly cautious on WD PCB replacements when it comes to getting an exact match though, as I am sure you understand.
Thanks,
John
John ,
I Only Know Mr Lee As i Use his Services ,You Have contacts Of Other People As Well .Whats Catchy In My Tag Line ?
Posted: March 17th, 2010, 14:14
I'm not sure if I can think of a rhyme with 'Dhillon'! If I get chance I will write a small data recovery related poem in ode to you.
John
Posted: March 17th, 2010, 17:46
cheadledatarecovery wrote:I'm not sure if I can think of a rhyme with 'Dhillon'! If I get chance I will write a small data recovery related poem in ode to you.
John
John ,
I think You Are Offended By Me giving you Advice From Whom To Buy From ,I would not Have Done That if You Had Mentioned This Earlier that You Know Mr Eric Lee .I wonder why Such Strong Reaction From you On Such a Small Basic Issue ,I Was Just Trying To Help you with the Resource I Deal With ,Its Strange And also Shocking for Me ,anyways cheers And Best Of Luck with your Purchase .
Posted: March 17th, 2010, 20:10
by networkpc3000
hi,
please contact me by email or MSN. both PCB i have in stock. i can provide FW to you which you request that you may no need to purchase entire drive. and others donor drive i can help also. but i need more detail for donor drive. looking forward reply from you soon. thanks.
Posted: March 18th, 2010, 6:27
Amarbir - I was being friendly! Nothing to take offense about.
Posted: March 18th, 2010, 10:57
by Eric Lee
Thanks a lot for recommendation, Mr. Amarbir ^^
Hi, John,
As I we discussed before, for many PCBs, match PCB number " 2060-******-0** REV * ", and then swap rom chip before swap PCB, if the HDD problem is from PCB, that should be OK.
And also there have some capacity probelm in some of the models. Remembered to pay attention to before manage will be OK too.
Eric
