| Wanted PCB Seagate http://forum.hddguru.com/viewtopic.php?f=15&t=15481 |
Page 1 of 1 |
| Author: | sub baru [ April 16th, 2010, 10:21 ] |
| Post subject: | Wanted PCB Seagate |
Hello, We have a fried pcb of an Seagate barracuda 7200.10 Numbers on the PCB: 100442000 REV A Chip ST V548A Numbers on the HDD ST3250310AS P/N: 9EU132-566 Firmware : 3.AAA Date code: 08122 Site code : SU Does anyone have such a PCB?? If i find an PCB 100442000 REV A with the V548A will that work or is it depending on the firmware etc.?? Regards |
| Author: | networkpc3000 [ April 16th, 2010, 20:11 ] |
| Post subject: | Re: Wanted PCB Seagate |
hi, have it in stock. please contact me by email or MSN if need. thanks. |
| Author: | fzabkar [ April 17th, 2010, 3:24 ] |
Can you see any physical damage? What are the failure symptoms? Depending on the fault, a DIY fix may cost you nothing. If this is your board ... http://ep.yimg.com/ca/I/yhst-4446369223 ... 00_4730136 ... can you identify the faulty component(s)? |
| Author: | Eric Lee [ April 17th, 2010, 11:23 ] |
Hi, We have this working PCB too, pls contact my hotmail. Thanks Eric |
