Need PCB for ST3320620AS.
Posted: May 13th, 2010, 4:36
Good day,
I have suffered a hard drive failure which caused me to lose years of work. Being a freelancer this is quite a problem. I know I should have backed up.
Thing is i would like to try to get everything back. From the trouble shooting I found that once in a blue moon I can acutally access the drive and try to get stuff off. I got about 2gb of work off before the hard drive just stalls, to bad there is about 100gb of stuff I need to retrieve. I hope the is PCB related so I would like to aquire another one and hopefully recover most of my stuff.
The specs are..
Seagate 7200.10 320 GB
Model number: ST3320620AS
P/N: 9BJ14G-308
Firmware: 3.AAK
Site Code: WU
Date Code: 07325
Capacity: 320GB
Is this enought or is there more information needed.
Also I found similiar HDD available at a online shop. After speaking to the tech he confirmed the following specs.
P/N: 9BJ14G-308
Firmware: 3.AAK
Site Code: SZ
Date Code: 0752-4
Capacity: 320GB
Just a few questions.
1st. Would it be possible to do a PCB swop without the whole firmware calibration needed?
2nd. If I have these two drives, what would a data recovery center plus minus charge to just swop the discs indside the drives?
Thanks in advance for any advise. Also if someone has the exact PCB I have, please let me know.
The specs are..
P/N: 9BJ14G-308
Firmware: 3.AAK
Site Code: WU
Date Code: 07325
Capacity: 320GB
P/N: 9BJ14G-308
Firmware: 3.AAK
Site Code: SZ
Date Code: 0752-4
Capacity: 320GB
