Wanted WD10EAVS-00D7B0
http://forum.hddguru.com/viewtopic.php?f=15&t=15926
Author:  louisloo99 [ May 28th, 2010, 4:49 ]
Post subject:  Wanted WD10EAVS-00D7B0
Hi
Anybody has this Western Digital Cavair 1.0TB
Model No. WD10EAVS-00D7B0
DCM HHNNHV2MFB
R/N 701537
Date: 03 June 2008
Pls PM me if you have.
Tks
Louis
Author:  harddrivespecialist [ May 28th, 2010, 9:48 ]
Post subject:  Re: Wanted WD10EAVS-00D7B0
You need a whole drive or PCB?
Author:  networkpc3000 [ May 28th, 2010, 23:28 ]
hi,
i can help. please contact me by email or MSN if need. thanks.
Author:  Eric Lee [ May 29th, 2010, 0:25 ]
We have this kinds of working PCB in stock, but for this kinds of PCBs, you need to reprogram rom in main chip.
Eric
Author:  louisloo99 [ May 29th, 2010, 6:29 ]
i'm looking for the whole drive with the PCB..my first Data Recovery project...
Author:  harddrivespecialist [ May 29th, 2010, 10:40 ]
Good luck!
Author:  networkpc3000 [ May 30th, 2010, 20:05 ]
hi,
please contact me by email. i need more detail and i could help. thanks.
Author:  louisloo99 [ June 19th, 2010, 3:00 ]
Dear All
My friends advise that I should look for the PCB replacement, not the whole drive.
Kindly advise if you have this replacement..for WD10EAVS-00D7B0.
PCB No. 2060 701537 004 REV A
pls post reply or PM me.
Tks
Louis
Author:  fzabkar [ June 19th, 2010, 3:31 ]
Read this thread:
verbatim-western-digital-1tb-ext-drive-not-powering-t14369.html
Does your board have an 8-pin serial EEPROM chip at location U12 below the Marvell MCU (big "M")?
If not, then you will probably need to transfer the internal ROM contents of the Marvell chip from patient to donor. A straight board swap won't work.
There are companies offering a ROM transfer a service for $10, if you buy a PCB from them.
Author:  louisloo99 [ June 19th, 2010, 5:09 ]
The EEPROM data is most probably in the MCU. I think the WD Doctor will be able to read the data in ROM and transfer the data over..
Do you use the P3000 or the Salvation Data Suite? which is better?
I just need the PCB replacement.
thanks
Author:  fzabkar [ June 19th, 2010, 5:20 ]
thanks
Sorry, I mistook you for an end user.
As for the DR products, I use neither. I'm not a DR guy.
Author:  louisloo99 [ June 19th, 2010, 16:10 ]
No problem fzabkar...you are just being helpful..
I am still new and appreciate all the help.
Do you have the PCB that I am looking for?
Author:  fzabkar [ June 19th, 2010, 19:13 ]
No, sorry.
Author:  networkpc3000 [ June 19th, 2010, 19:19 ]
hi,
i have it in stock. and can help you program original FW into good PCB if you can send file of ROM data to me.
Author:  louisloo99 [ June 20th, 2010, 6:33 ]
Thanks for your offer to program for me...the joy is doing it myself and troubleshooting. and getting the experience at the same time...hehe..
Can you give me a quote and also send me a high quality picture of the chips and back of the PCB..
Tks
Louis
Author:  networkpc3000 [ June 20th, 2010, 19:00 ]
yeah. i can. but why you had to match with chip and label? :)
Author:  louisloo99 [ June 21st, 2010, 4:26 ]
actually, it is not a must...but if the chip can be the same,,better still :) right..because i check with another vendor, but he ask to give him the chip number also,,which i thot the same as you..why need to match the chip and the label..but i just gave him.
Author:  networkpc3000 [ June 21st, 2010, 18:51 ]
hi,
sent them to you by email already. do you think vendor which you mention is pro? or just vendor only? :wink:
Author:  louisloo99 [ June 23rd, 2010, 7:56 ]
my customer has suddenly decided to take back his disk..already more than a month..sorry guys for your trouble..
