| PCB for a WD800 needed http://forum.hddguru.com/viewtopic.php?f=15&t=15936 |
Page 1 of 1 |
| Author: | athlesi7 [ May 29th, 2010, 4:03 ] |
| Post subject: | PCB for a WD800 needed |
i get i IDNF problem and i assume that there is a PCB problem. the model number is : WD800JB-00CRA1 thank you |
| Author: | networkpc3000 [ May 30th, 2010, 20:08 ] |
| Post subject: | Re: PCB for a WD800 needed |
hi, please let me know the model of your drive. or you can contact me by email/MSN directly. thanks. |
| Author: | Eric Lee [ May 30th, 2010, 22:14 ] |
Hi, Pls let me know the PCB number like 2060-******-00* REV * so that we could match what you need. Pls contact my hotmail. Thanks Eric |
| Author: | unknown [ May 31st, 2010, 3:44 ] |
Quote: get i IDNF problem and i assume that there is a PCB problem. It's not the PCB. TRANSLATOR Use the search button above. |
| Author: | athlesi7 [ May 31st, 2010, 5:15 ] |
the number is 2061-001102-300 E. is the translator problem fixed by changing the pcb (swapping the chip i mean) or can it be fixed with F/W update? thank you for your response |
| Author: | unknown [ May 31st, 2010, 5:30 ] |
Quote: is the translator problem fixed by changing the pcb (swapping the chip i mean) No. Quote: or can it be fixed with F/W update? No. You will need a special equipement SW/HW to regenerate translator. And the most important thing : you have to know what you are doing. If your data is important then you have to seek for a pro. It's a strange issue for you, but DR company/man doing this almost everyday. good luck |
| Author: | rzr [ December 26th, 2010, 20:43 ] |
can you tell more on this "special equipement" ? ps: got IDNF too |
| Author: | unknown [ December 26th, 2010, 22:12 ] |
rzr wrote: can you tell more on this "special equipement" ? ps: got IDNF too ATOLA Insight / PC3K / SD tools .... etc What's your HDD model ? |
| Author: | rzr [ December 27th, 2010, 5:11 ] |
| Post subject: | WD400BB-00CCB0 : translator issue |
unknown20010 wrote: What's your HDD model ? WD400BB-00CCB0 seems to be a translator issue too see the logs about it : http://rzr.online.fr/q/ata |
| Author: | unknown [ December 27th, 2010, 8:45 ] |
PM sent. |
| Author: | rzr [ December 27th, 2010, 21:33 ] |
many thx ... I wish i could do this from linux , but I managed to boot a livecd of windows and reset the translator now i'm dumping a broken partition w/ ext3 fs while i am here do you know if this device has issues w/ SMART capabilities I cant manage to set it back ... |
