HDD GURU FORUMS
http://forum.hddguru.com/
Need working PCB board for a WD2500BB-22GUC0 drive
http://forum.hddguru.com/viewtopic.php?f=15&t=16212
Page 1 of 1
Author:  JDE2002 [ June 27th, 2010, 11:47 ]
Post subject:  Need working PCB board for a WD2500BB-22GUC0 drive
I am in need of a working PCB board for a WD2500BB-22GUC0 drive.
Code on PCB: 2060-701266-001 REV A
Code on White Sticker: 2061-701266-200AG
Card date of manufacture: 2004
Main controller WD70C26 - GP v2.1
Disk date of manufacture: 5-26-05
DCM: DSBACVJAH
my email is JDE2002@cox.net
Author:  networkpc3000 [ June 27th, 2010, 22:06 ]
Post subject:  Re: Need working PCB board for a WD2500BB-22GUC0 drive
hi,
i have this PCB in stock. and no need matching too much if just need PCB. you should find out same model of PCB will be fine. pelase contact me by email or MSN if need. thanks.
Author:  Eric Lee [ June 27th, 2010, 22:16 ]
We have this working PCB in stock too, pls contact my hotmail.
Eric
Author:  JDE2002 [ June 27th, 2010, 23:33 ]
Franc: per your request.
The drive was working fine. The next time I plugged it into the computer, (it’s in an external case), it would not spin up. It never made a sound like it was going bad. It simply wouldn’t spin. What I believe occurred is a chip overheated. I’ve uploaded three photos and the one with the yellow circle is the suspect chip.
Author:  fzabkar [ June 27th, 2010, 23:43 ]
It looks like your motor controller chip has failed. When replacing the PCB, you may need to transplant the 8-pin serial EEPROM chip at U12 from patient to donor, but your board supplier should be able to confirm that.
If you are not comfortable with soldering, then your local TV/AV repair shop should be able to handle it.
You may also like to measure the resistances of the motor windings to confirm that none are open or shorted.
Author:  JDE2002 [ July 8th, 2010, 20:57 ]
Okay, I purchased a “new” PCB that had the same model and revision numbers. I installed it on the hard drive to see if it would work. The hard drive powered up and began spinning. However the computer would not pick up the hard drive. (It is in an external case). So, I took the “new” PCB to a computer store and they swapped the U12 chip from the old non working PCB board. I have reinstalled the “new” PCB board and the drive will not spin and, of course, will not read any of the data on the drive.
Any suggestions?
Author:  networkpc3000 [ July 8th, 2010, 21:13 ]
check ROM chip and re-soldering.
Author:  harddrivespecialist [ July 9th, 2010, 10:34 ]
JDE2002 wrote:
Any suggestions?
Unfortunately, someone either ruined your ROM chip or your PCB.
We receive those cases every other day in our shop.
Procedure seems very simple, but it is a very dangerous and costly to fix once its broken.
Possible Preamp damage could be caused by doing this is wrong way, which will cost thousands to recover your data.
Say special thanks to fzabkar for referring you your local TV/AV shop, now your repair will cost you time more of original quotes/prices.
Author:  networkpc3000 [ July 9th, 2010, 19:26 ]
may be. i have been provide some ways to him for check it's PCB problem or no. waiting for report.
Author:  fzabkar [ July 11th, 2010, 6:24 ]
That's a reprehensible accusation. I will continue to refer people to their local TV/AV shop for simple soldering jobs. That's what real technicians are trained to do, unlike DR pros who do most of their work from behind a keyboard.
http://www.phpbb.com/
