HDD GURU FORUMS
http://forum.hddguru.com/
Wanted: Controller for MJA2500BH (Fujiutsu SATA 2,5" 500GB)
http://forum.hddguru.com/viewtopic.php?f=15&t=16558
Page 1 of 1
Author:  ikea110 [ August 2nd, 2010, 10:57 ]
Post subject:  Wanted: Controller for MJA2500BH (Fujiutsu SATA 2,5" 500GB)
Hi!
I am looking for a controller-board for a Fujiutsu MJA2500BH disk (Fujiutsu / SATA / 2,5" / 500GB / fabrication 12/2009).
Black printed Letters on the controller-board "214EE CA21350-B12X" and on the left side the letters (etched into the board) "MDK 339V-0 N".
I bought a disk with fabrication date 06/2009 with the label "211EE CA21350-B12X" (in difference to 214EE, which I need). Didn't work out, only clicking noises, seems not to find track zero.
With the old faulty controller ist spins up right, but no access possible.
Is anybody able to help?
Thanks a lot!
Author:  drc [ August 2nd, 2010, 11:01 ]
Post subject:  Re: Wanted: Controller for MJA2500BH (Fujiutsu SATA 2,5" 500GB)
Doesn't work like that,
You need to get a real diagnosis
Author:  ikea110 [ August 2nd, 2010, 11:09 ]
What do you suggest me to do / check / read?
Windows Eventlog shows Controller Errors, and all symptoms seem to me to be caused by a bad controllerboard...
Thanks for further hints !
Author:  drc [ August 2nd, 2010, 11:24 ]
You can use something like MHDD to check it outside of windows. Windows is not a good environment to work with a bad disk.
Author:  networkpc3000 [ August 2nd, 2010, 21:29 ]
hi,
have you check it there has ROM chip on your PCB? have you swap it? this PCB should be work for your drive. post more detail please. :)
Author:  networkpc3000 [ August 2nd, 2010, 21:51 ]
for this PCB. it has no ROM chip. that you had to swap the MCU(largest BGA one) i have 212EE :)
Author:  nande [ August 2nd, 2010, 23:29 ]
Or you can find exact match of firmware xxxxxx - xxxxxxxx on label.
Author:  ikea110 [ August 4th, 2010, 6:39 ]
Hey drc, networkpc300 and nande - thanks a lot for your hints.
Wherefor do I need the "exact match of firmware" which nande mentions?
Because I think this topic is now changing from hardwaresearch to a recovery-discussion, I opened a new topic in the sub-forum "Hard Disk Drives: data recovery and repair". You can find it here:
--> recover-mja2500bh-sata-500gb-with-encrypted-partition-t16577.html
I would be very thankful if you read it, I tried hard to describe every detail...
THANKS A LOT !!!
http://www.phpbb.com/
